Page 6 of 6 FirstFirst ... 456
Results 51 to 58 of 58
  1. #51
    Jul 2015
    California
    new BT module and new HiFi Control set plugged in. I also updated the FW for new hifi control set and added voice pack. anyway to test the new setup? I tried turning off BT on my phone just to see if parking sensors would play through hifi speaker but got nothing the LED still blinks red but no beeping.
  2. #52
    Quote Originally Posted by SurrealOne View Post
    If you have the new BT module and you disconnect the BT on your phone the ALP will reboot with the wired controller.
    SurrealOne (02-12-2016)
  4. #53
    Jul 2015
    California
    Got it I will give that a go. But will parking sensors beeps come out of the HiFi speaker?
  5. #54
    Yes, If you dont have them turned off otherwise it will just blink. A short press of the power button toggles the parking alerts on and off.
  7. #55
    Jul 2015
    California
    Yes Sir that did it.. Thanks Again!
  8. #56
    May 2017
    I am not sure if this post goes here or not, but it's related to the new V2 Bluetooth. Prior to having purchased the Bluetooth, I have ran the Hi Fi setup, and this question pertains to the LED on the Hi Fi device. Previously, before the installing the Bluetooth, my setup for my LEDs were Dark and Constant. This allowed my external LED on my dash display to be dark unless there was an alert, while the Hi Fi controller LED's stayed illuminated. After installing the the Bluetooth, and when the Bluetooth is not connected, I cannot get the LED on the Hi Fi to stay illuminated for more than 10 seconds. It will boot up and all is well, then the both the LED's, the external and the controller will go out after 10 seconds. Is this a normal operation, or am I doing something wrong?
    Thanks,
    Fireman603
  9. #57
    May 2017
    I figured out my problem. (Feel Stupid). Should have been using DIM and not Dark.
  10. #58
    Quote Originally Posted by fireman603 View Post
    No big deal. It happens to all of us at one time or another.
