Results 1 to 10 of 12
    Dec 2015
    m235i sensor positions
    I looked at some of the other BMW installs but the front grills of the m235i appear to be a little different so I wanted to get some feedback on positioning.
    So obviously the green configuration would be best, but could I get by with blue or red? Also are these locations too low below the headlights?
    Where are you located and where do you travel?
    Dec 2015
    I live in CT and usually stay in the area (CT, NY, NJ, MA). I have a road trip early next year where I'll be going through OH which I know is a laser happy state.
    Quote Originally Posted by lcasale View Post
    I would go green and know you are protected from everything out there at this time. By skimping on the 3rd head you might be fine in your area against current guns but you might as well go with the 3 and if new guns come into your area your system will already be ready for it.
  5. The Following User Says Thank You to BestRadarDetectors For This Useful Post:
    lcasale (12-17-2015)
    I would recommend a Triple for the Front,too. I recently Tested an M4 w/ similar placement to your Green locations... He was bullet proof !
    I would suggest pulling the outboard 2 Transponders more inward such that their spacing distance to the Center one is 22-23" separation between each one of them.
    Make sure you have X-band Turned-ON when in Ohio. You'll find just about every Trooper w/ the large MPH antenna mounted on the roof racks. I was out there on a Chicago trip ~month ago, never got shot once b/c of the 12 Troopers I saw on I-80/I-90, everyone already had a victim pulled over in the breakdown lane.
  7. The Following 2 Users Say Thank You to RedRocket For This Useful Post:
    lcasale (12-17-2015), modsl55amg (12-17-2015)
  8. #6
    Dec 2015
    Awesome, thanks for the input guys. I'll go for the three head install and make sure they're all within the proper spacing distance. I posted a separate thread on this but do you guys have any insight on a good location for the control box on these cars? There's a knee airbag under the steering wheel which is where I had my LI install on my 335 so I'm not sure if there's space for it down there anymore.
  9. #7
    Control box is not large and there should be no issue mounting under the dash.
  10. #8
    also the added benefit of fitting the third head,all the install done one hit, fit and forget
  11. #9
    Dec 2015
    Haha very true. So one more detail that I want to make sure I get right. The outer grill slots are recessed quite a bit compared to the center one. I'm assuming I still want the outer sensors pointing straight ahead, but should I avoid being too close to the inner edge? Or will the center sensor pick up the slack there?
  12. #10
    I would consider mounting the 3rd head vertical on one of the innermost slats of one of the kidney grill. I have 3 heads on the front of my E90 and have had 4 laser saves so far (10k miles in 2.5yrs, I don't drive a lot)
    Remember to shim it so that it's perfectly vertical if the most inner slat is not vertical (looks like it's not)
