Results 1 to 6 of 6
Thread: Odd audio alert
    Senior Member Nanook's Avatar
    Apr 2014
    Odd audio alert
    I've noticed recently when being targeted that the control unit where alert sound comes from makes a different sound now...initiates with a crackling fast intermittant alert for a split second then immediately changes to the original solid beeeeep...could this be the gun used (I know it's a dragon) ..I'm hoping my unit isn't going south
    • '13 ML63 AMG - ALP 5 / STiR+ • '09 ZR1 - ALP 4 / V1 • '14 LEXUS RX350 - 9500ix • '14 HONDA CIVIC EX 9500ix • '16 TOYOTA RAV4 LTD 9500ix / ALP rear x 2 • '14 PORSCHE TURBO S ALP 5 /NET RADAR / STINGER / BLACKVUE
    Quote Originally Posted by Nanook View Post
    Not sure what you are referring to. If you record it I can tell you what you are hearing.
  3. #3
    Senior Member radargeek's Avatar
    Jan 2014
    York, SC
    Are you in Pro Mode? It could be the pulse blips you're hearing.
    Also, when I was bench testing my ALP, I found the siren would stutter/restart if I didn't aim Dragon pulses straight at the head. Maybe something like that is happening with yours?
    If I passed you on the right, YOU are in the wrong lane!
    2016 Encounters/Saves (to date): 33.8: 1/1 (last 4/13) | 34.7: 1/1 (last 3/11) | 35.5: 19/11 (last 8/28) | K: 1/1 (last 6/26)
    2015 Encounters/Saves: 33.8: 1/0 | 34.7: 13/4 | 35.5: 19/10 | K: 4/1 | LIDAR (sighted/hit with/save): 4/1/1
    ACTIVE CMs: Redline X, K, Ka 2,4,5,8 (highway/long trip RD) | New! V1C 3.8945 K, Ka CS, TMF2 w/YaV1 (in-town RD) | ALP Quad | BlackVue DR650GW-2CH
  4. #4
    Apr 2014
    Here is a short clip using my tester...note @ 34sec specifically...is this normal..I may be on pro mode I don't recall my last setting...if this is normal great !
  5. The Following User Says Thank You to Nanook For This Useful Post:
    alatilla (09-17-2016)
  6. #5
    Jan 2014
    York, SC
    Looks like you're in Pro Mode. The blippy tone + red (or yellow for rear hits) LED tells you when you're being targeted/picking up pulses. When the pulses stop, the LED goes out and you get the high pitched warning tone.
  7. #6
    Apr 2014
    Gotcha...these lastest alerts were the first since I installed the pro version so you've explained it thanks
