Results 1 to 10 of 12
  1. #9
    Jul 2015
    California
    Quote Originally Posted by sfscott View Post
    Hi all,
    I'm new to jammers and this site. Years ago, I used a V1 radar detector but left it off since it falsed so much. That and the Calif Highway Patrol wasn't using radar much if at all.
    I am about to take delivery of a new BMW X5 M-sport and have been researching the options on jammer/radar combinations. It's clear that people view AL Priority as the best jammer. Usually, that would be enough, but there are some wrinkles that I could use some help with.
    The confusion for me is that in CA, laser jammers are illegal, so people are saying that continuous jammers are a sure-fire way to get pinched here. The better option is a timed jam or a kill switch. That led me to consider the Escort 9500ci with laser shifters, esp since the laser shifter heads can be swapped with Laser Interceptor's vertically mounted versions. The downside to the Escort was the need to install a display and a control unit in the car, which is leased as well as really nice without modification.
    When visiting two local installers, both swore by the K40, which people on this and other forums dismiss as not worthwhile. One of the installers, who's been in business for 30 years recommended the K40 without reservation, citing performance, cleanness of installation and customer support. He represented that one of his best customers has put them in each of his 15 cars and has never had a ticket or a complaint. In fact, the guy was installing one for that customer on a $3million La Ferrari in the shop as we spoke. He also noted that the Dragoneyes were not used in CA and that the 4 sec jam to standby operation was optimal in CA so that the LEOs would not know that they were being jammed as they would if a jammer jammed to the gun. He also felt that the radar was very good and easy to use. This installer also sells AL/P and Escort so he is not biased because he doesn't offer the others. His assessment was similar to another installer that works closely with the local Porsche/Audi dealer.
    Both installers also said that they had experience installing on cars with active cruise control, blind spot warning and park distance warning systems, all of which my vehicle has.
    The K40 is expensive and not loved by the experts, so I am torn.
    For my situation and where I live, is the recommendation of the K40 fair?
    I also live in the Calif So CAL Orange county area. I have done lots of research asked lots of questions and I'm going with the advice that I got from this and other forums. BRD and RR are spot on with the AL-P and STi-R combo.
    I have my AL-P set to jam for 6sec I think and that's more then enough time for me to reach the PSL. And I will kill my jammers with a push of a button. Keep in mind if you get asked about your jammers it is a parking sensor. BTW the parking sensor really works well. Easy setup easy for installer to install.
  2. The Following User Says Thank You to SurrealOne For This Useful Post:
    modsl55amg (08-27-2015)
