Thanks for the help/advice. Do all three sensors have to be perfectly in line then? Can I place the two on the outer edges as you suggest in the middle row and then place the center head below in the bottom row of the top grill area directly under the Ford logo? (So the center head will sit a few cm below the two mounted in the middle section of the grill?
