Results 1 to 5 of 5
    With dragons you will need 3 heads up front!
    Move the red sensors out to the max edges on your grill and put the 3rd sensor right in the center under the ford emblem--you will be good to go~~~
  2. The Following User Says Thank You to Holla For This Useful Post:
    modsl55amg (08-24-2015)
    Aug 2015
    Thanks for the help/advice. Do all three sensors have to be perfectly in line then? Can I place the two on the outer edges as you suggest in the middle row and then place the center head below in the bottom row of the top grill area directly under the Ford logo? (So the center head will sit a few cm below the two mounted in the middle section of the grill?
    Quote Originally Posted by jeff106 View Post
    Do all three sensors have to be perfectly in line then?- that's preferred, but CM one slat lower should be ok.
    Yeah, put the 2 on the "underside" of the FORD emblem slat & at the extreme edges of grill on each side. Put the CM Sensor on the "underside" of the bottom slat below the emblem.
    Insure the Sensors are "bubble" level & pointed straight ahead...do not "parallel" the curve of the body !
  5. The Following 2 Users Say Thank You to RedRocket For This Useful Post:
    jeff106 (01-24-2016), modsl55amg (08-24-2015)
  6. #4
    I would not say 3 heads are required but rather 3 heads is preferred. This is not a large car and we have tested many similar vehicles with JTG performance even against Dragon guns with 2 heads.
  7. The Following 3 Users Say Thank You to BestRadarDetectors For This Useful Post:
    jeff106 (01-24-2016), modsl55amg (08-24-2015), OrlNmE (08-24-2015)
