Results 1 to 10 of 13
    South Jersey
    Double-Sided Tape: Which Type/Brand is Best for Long-Term Holding Power?
    Do any members have a recommendation as to which type or brand of Double-Sided Tape is the best to use for Long-Term Holding Power in securing ALP sensors to their mounting positions?
    The netherworld of the Force
    3M molding tape will do the trick!
    STi-R: the ORIGINAL!
    AL Priority TRIPLE
    ALP Hi-Fi Module
    ALP Add-on wish list:
    2 more heads
  3. The Following 2 Users Say Thank You to Qui-Gon For This Useful Post:
    modsl55amg (08-03-2015), Radarrob (08-03-2015)
    Member wirelessandy's Avatar
    Oct 2014
    SF, CA
    3M "VHB" style tape. If you properly prepare your surfaces clean with alcohol wipes (and let dry!) it'll glue a fart to an ice cube.
    2013 Subaru WRX STI hatchback/ Valentine One / AL Priority QUINT
  5. The Following 4 Users Say Thank You to wirelessandy For This Useful Post:
    EightyFiveHundred (08-04-2015), modsl55amg (08-03-2015), Radarrob (08-03-2015), RedRocket (08-03-2015)
  6. #4
    Junior Member LI2624's Avatar
    Jul 2015
    Quote Originally Posted by wirelessandy View Post
    +1, including the fart and ice cube
  7. The Following User Says Thank You to LI2624 For This Useful Post:
  8. #5
    just out of interest, how difficult is it to remove the item from the vhb tape
  9. #6
    You can get some fishing line to slice thru the sticky tape then some goof off and a razor to clean everything up.
  10. The Following 4 Users Say Thank You to Holla For This Useful Post:
    curmudgeon (08-04-2015), dinkydi (08-03-2015), ECMExpert (08-14-2015), modsl55amg (08-03-2015)
  11. #7
    Quote Originally Posted by Qui-Gon View Post
    Stuff is so strong it will hold pictures up to 200lb.
    Telling the truth and exposing the lies in the lidar and radar industry
    "I'm interested to see how well you do.I never seen a car JTG before would be a first for me.."
  12. The Following User Says Thank You to Radarrob For This Useful Post:
  13. #8
    Gwinnett Ga.
    Had my old M47 attached using it. Had no problem get it off.
    ALP Quint - HiFi BT
    Net Radar Front and Rear
    Note 2 dedicated ALP Display
    Uniden LRD 950
    BlackVue 750
    Waze
    IPhone User 6s plus
    Wilson Moble 4G Cellphone repeater
  14. The Following User Says Thank You to Nicholat For This Useful Post:
  15. #9
    South Jersey
    If I need to use two (2) pieces of the 3M "VHB" tape between the sensor and the mounting surface, for spacing purposes, do I need to do anything special where the two flat pieces of tape join to each other? Or can I just place one piece of tape upon the other? (In other words, one piece of tape will be on a surface of the car, the second piece of tape will be on the sensor. Can I just push the tape on the sensor right onto the tape on the car's surface?)
  16. #10
    Gwinnett Ga.
    You can just add pieces as needed. When I did my last ALP install, I used the brackets, problem with tape is that it very hard to make the needed small adjustment after you get them installed. Alignment is very important. I recheck my all the time and can make the needed adjustments. They will move with time.
    ALP Quint - HiFi BT
    Uniden LRD 950
    BlackVue 750
    Waze
    IPhone User 6s plus
  17. The Following User Says Thank You to Nicholat For This Useful Post:
    modsl55amg (08-04-2015)
