Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 118
  1. #31
    Moderator Salty's Avatar
    We should consider closing the list b/c of so many attending & a large arsenal of Lidars to cycle through.
    Members need to bring fluids for themselves so we don't have any hydration problems, something for lunch also...it'll be straight out running- we won't have time for eating breaks.
    We are going to list all the lidars that will be at the meet. However, you are right. We are not going to have time to test all of them. So we'll start with the most important ones for our areas, and work our way down. If we have time, we can test the rest of the gun.
    One of the worst things you can be in life is blindly obedient to authority. It’s a forfeiture of your personhood—an acknowledgement of your nothingness.
    -Kevin Geary
  2. #32
    Quote Originally Posted by Salty View Post
    Would be nice to know what systems people are also coming down to be tested. If ALL ALP's then there is no need to test multiple Compacts or DragonEye's guns because if they can jam the harder ones than there is no need to test the easier ones and we can get more people tested. I dont expect to be able to do testing again soon with my schedule so if anyone is on the fence I would highly suggest making this meet.
    spankyaf (07-30-2015)
  4. #33
    I've already composed the list & it looks like it's near 100 % AL-P so far.
    jk111 - no Parking Sensors listed
    Lenin - no Parking Sensors listed
    modsl55amg - Quint
    JoeBrunoDesign - Quad
    itwasntme - Quad
    ddlopresti - has cancelled
    I also have the running order established by Date/Time sign-ups for the Meet.
    I can be the caboose if Andrew21 wants his ride Tested w/ me as Pilot.
  5. The Following User Says Thank You to RedRocket For This Useful Post:
    Salty (07-30-2015)
  6. #34
    itwasntme - the only Quad
    specifics - the only Triple
    I can be the caboose if Andrew21 wants his ride Tested.
    I thought you wanted to shoot Specifics...
  7. #35
    Awesome! Thanks RR!
    -Kevin Geary
  8. #36
    I only have 1 LE-10 notch on my Pistola- another who has been on my Hit List for take down was the 2nd Owner I knew of.
    Guess his trip to Philly isn't happening, so I'm the Start Line S.o.B.
  9. #37
    Jan 2015
    I have two ALP sensors in the front and two in the rear. I have a fifth sensor that I would want to try and fit in the best spot in the front using two sided tape for now.
  10. The Following User Says Thank You to Lenin For This Useful Post:
    RedRocket (07-30-2015)
  11. #38
    Quote Originally Posted by Lenin View Post
    Make sure the 3rd (Front CM) Sensor is connected to the F2 port on the Control Box.
  12. #39
    will the stinger laser be @ the for testing
  13. #40
    That would be nice to have at the test, hopefully someone will be there!
  14. The Following User Says Thank You to Holla For This Useful Post:
    dinkydi (07-30-2015)
