Results 1 to 8 of 8
    Jul 2015
    California
    After install question
    So I had my install done yesterday and everything looks good going to load the USB stick today.
    Should the ALP unit turn on and off when I start my car? The installer hooked it up to a constant power source and told me I need to turn it on and off on my own.
    Quote Originally Posted by SurrealOne View Post
    *Should the ALP unit turn on and off when I start my car? The installer hooked it up to a constant power source and told me I need to turn it on and off on my own.
    * - That's not a good practise to do, when cranking the engine a transient power surge could damage the electronics, it's best to wait till the engine is running before turning on your Parking Sensors or RD. Always turn them off before shutting the engine off...otherwise, you'll probably forget the next time that you left everything ON & when cranking the engine next day could result in damage.
  3. The Following User Says Thank You to RedRocket For This Useful Post:
    Tman (07-19-2015)
    Jul 2015
    That's pretty cheesy. He should have connected it to a switched circuit. There is no reason to have it on if your not driving.
    Jul 2015
    California
Size:  154.9 KBThe install directions say to connect the red wire to a switched positive power supply.
    Have him move the wire to a switched circuit, pain in the butt to keep it on a Hot circuit, should take him 5 minutes to make that change
  7. The Following User Says Thank You to Holla For This Useful Post:
    SurrealOne (07-19-2015)
  8. #6
    Jul 2015
    California
    I have the user guide and I know what all the LED lights are for but what is the blue led for?
  9. #7
    That's just another visual alert you can stick someplace in your view, so when you are hit it will also flash to gain your attention
  10. #8
    Blue LED means your system is in defense mode and its ready to defend you.
  11. The Following User Says Thank You to BestRadarDetectors For This Useful Post:
