Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: ALP issue ?
  1. #11
    Senior Member Nanook's Avatar
    Apr 2014
    As I mentioned LID was 4..just now I changed to 8..I always try to slow..then switch off...as I say it is very possible I shut down before slowing sufficiently but doubt it
    • '13 ML63 AMG - ALP 5 / STiR+ • '09 ZR1 - ALP 4 / V1 • '14 LEXUS RX350 - 9500ix • '14 HONDA CIVIC EX 9500ix • '16 TOYOTA RAV4 LTD 9500ix / ALP rear x 2 • '14 PORSCHE TURBO S ALP 5 /NET RADAR / STINGER / BLACKVUE
  2. #12
    Apr 2014
    Well I could unplug it I guess if it's detrimental
  3. The Following 2 Users Say Thank You to Nanook For This Useful Post:
    RedRocket (06-30-2015), Tman (06-29-2015)
  4. #13
    Remove the bottom head and put it in the front and leave the 2 in the license plate area and you will have better protection. If you just disconnect the bottom sensor you will need to move the ports and correct them and use the correct R1 & R2 ports and use the F1 & F2 ports for the front sensors.
  5. The Following User Says Thank You to BestRadarDetectors For This Useful Post:
    jfr3170 (06-29-2015)
  6. #14
    Apr 2014
    Okay..appreciate the advice
  7. #15
    Quote Originally Posted by Nanook View Post
    You got hit with a newer Dragoneye DragonCam I have no doubt about it and LID time did not cause the issue the install did. In the past you might have been hit with older Laser Ally DragonCam's where your install would have Been sufficient.
  8. The Following User Says Thank You to BestRadarDetectors For This Useful Post:
  9. #16
    Apr 2014
    Must I do a default reset after re-configure?
  10. #17
    Yes, Also realize a rear shot especially on a DragonCam will be focused on your license plate. The 2 heads in the license plate area where you have them would have saved you and bought you plenty of time to slow. The 3rd head on the bottom really screws the process all up. 3 heads works great if you spread heads out and keep one dead center.
  11. The Following 2 Users Say Thank You to BestRadarDetectors For This Useful Post:
    jfr3170 (06-29-2015), modsl55amg (01-17-2016)
  12. #18
    Senior Member Tman's Avatar
    '' You got hit with a newer Dragoneye DragonCam I have no doubt about it ''
    Curiosity ticks me : how do you deduct this conclusion , if it is not too indiscreet ?
    Also , do you think about dulling his chrome , is it of any help ?
    Thanks.
  13. #19
    Quote Originally Posted by Tman View Post
    Thanks.
    The rear head to the ground is what caused the failure. I knew it would happen and warned against this install when it was done. Re-read the original install thread.
  14. The Following User Says Thank You to BestRadarDetectors For This Useful Post:
    Tman (06-30-2015)
  15. #20
    We should use this case as an intox tool toward leos : those things don't work .
