Results 1 to 8 of 8
    Ohio
    Error 2 then Voice Pack lost
    So this has happened twice now, first time I thought it was a fluke, second time happened yesterday and now I am concerned. What happened was I would start the car, get an "Error 2, check cables or defective sensor" message so I turn it off then back on which takes care of the error but now my voice pack is gone and I just get beeping instead of voices. Restarting does not work and the only way to fix it is to reapply the voice pack. Anyone experience this before?
    Senior Member dukes's Avatar
    Alberta, Canada
    Quote Originally Posted by JStump2490 View Post
    If you are getting an error 2 you should find out which head is causing it. Unplug all your heads and plug in each head individually and test them to determine which head is causing the error.
    Error 2 is most likely interference and instead of turning the system off you should just drive and see if it clears itself normally if it does not stop then you have a sensor that might be failing. After you installed the system did you perform a factory reset so the ALP can learn all the attached sensors and their positions? If you do this and a sensor fails you will get a sensor error instead and the ALP will point you to the failing sensor. If you never performed the factory default after the install pull a statistics report and verify that it shows all sensors are attached. I have never seen anyone have to re-install a voice pack after an Error 2 but maybe because you shut it down during the error it had something to do with it.
  4. The Following 3 Users Say Thank You to BestRadarDetectors For This Useful Post:
    dukes (06-03-2015), modsl55amg (06-03-2015), Qui-Gon (06-03-2015)
    Ohio
    I believe I did a reset because I followed the install instructions I found on here, and I would test the head individually but it only happens once in a while. The time before this was over 3 weeks ago and it happened while I was driving and would not stop until I turned off the system. I will try a factory reset and reapply the updates and see what happens.
    Ohio
    Well here are the stats I pulled
    Device information
    Serial number xxxxxxx
    Firmware version 5.1.2
    Region North America
    Power Cycles 840
    Control Set FW version 5.3
    Control Set HW version 2
    Activated locks not active
    Hardware version 2
    Connected sensors
    Connected sensors when manually memorized Front1, Front2
    Connected sensor (actual) Front1, Front2
    Settings
    Audio Volume 5
    Parking detection range 9
    Silent Power-up Disabled
    Dark Mode Dimmed
    Parking enabled sensors Front1, Front2
    GPS Antenna None
    PDC Speed Limit NONE
    Working mode Parking and Laser Interference Defense
    Pro mode Enabled
    LID Speed Limit NONE
    Below set LID Speed Limit PDC & DLI
    Radar Antenna Model Not Connected
    Radar Settings
    LID Time 5 seconds
    After LID timeout DLI & Warm up
    Audio volume of Laser Alerts 6
    Audio volume of Radar Alerts 6
    Menu button short press function None
    Specific LID settings
    Vitronic Poliscan
    Speed scanner Enabled
    Unicam Camera
    Section speed control All sensors ON
    NJL SCS
    Speed-laser Enabled
    Riegl
    Speed-laser Enabled
    Trafic Observer
    Stalker
    Speed-laser Maximum Power
    Alerts by Source Speed-laser
    Marksman and UltraLyte 1
    Atlanta SpeedLaser Stealth 0
    Kustom ProLaser 1 0
    Kustom ProLaser & ProLite 0
    Redspeed SpeedGuard 0
    Riegl 0
    Stalker 0
    LTI Truspeed 11
    Unipar - SL700 0
    NJL SCS 101 & 102 0
    Jenoptik – Laveg 0
    Leivtec XV 2&3 0
    Laser Ally 0
    Cam S1 0
    Error Sensitive Lasers
    Jenoptik LaserPatrol 0
    Jenoptik TraffiPatrol XR 0
    ProLaser 2 & Atlanta SpeedLaser 0
    Speed Section Control
    Camea - IR Camera 0
    Speed Scanner
    Traffic Observer 0
    Vitronic Poliscan 3
    Radar
    K-band 0
    Ka-band 0
    X-band 0
    POP 0
    MultaRadar CD 0
    Do you only have 2 sensors?
  8. #7
    Says Dual in his Sig, Tom
  9. #8
    Ohio
    Yes, just 2
