Well, I finally figured it out. Turns out it wasn't an electrical issue after all. It was interference from the collision avoidance system on the front of my car. The 'camera' uses a laser frequency and runs through its diagnostics the same time as the ALP startup, even though I disabled it in the vehicle settings.
The solution was to put a couple of pieces of electrical tape over that portion of the windshield. If I can find the fuse for it and pull it.......
If you install your ALP and get a solid green light on startup and it won't go into defend mode (flashing blue light), this is your problem.
Also note- it takes a full 60 seconds or so after startup for the ALP 'setup' settings to go into effect. Mine cycles into defend mode after about a full minute, then takes another 15 seconds or so to go into dim mode.
- You may not post replies
- You may not edit your posts
Forum Rules
