Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 67
  1. #51
    Jul 2015
    California
    So parking sensors do not work with BT
  2. #52
    Member EightyFiveHundred's Avatar
    Feb 2014
    Surf City USA
    Quote Originally Posted by SurrealOne View Post
    They do...if you're connected with your app.
    If you're not running your app, you're not connected to the ALP.
    4 Doors, 10 cylinders, 8500 redline, three pedals, and 206 mph club, plus F/R Black Box G1W-H, RedLine and ALP
  3. The Following User Says Thank You to EightyFiveHundred For This Useful Post:
    SurrealOne (11-13-2015)
  4. #53
    Dec 2015
    I know they are not completely even (brackets came loose) but how is this location? Should I move them higher? FWIW they are exactly 22" apart (Outside to outside). Sorry for the cell phone pic.... Name:  Laser.jpg
  5. #54
    You're limited in moving them higher unless willing to cut the upper grill. Why not have it Tested first before doing any cutting elsewhere. Make sure you have both Transponders pointed straight ahead when you fix the loose brackets. Following the curvature of the body is a no-no.
  6. #55
    Dec 2015
    I am not opposed to cutting (I would buy another OEM grill first) and I would love to have it tested. Being in VA is there anywhere close that could assist me?
  7. #56
    Quote Originally Posted by Bassman0221 View Post
    I'm afraid not close by that I'm aware of.
  8. #57
    Feb 2016
    Suggestions for 3 sensor front placement on my car?
    Also, my front grill is attached to the hood. Does this cause any problems?
  9. #58
    Nov 2016
    Can all 5 sensors be utilized on the front of a 2017 Camaro?
  10. #59
    Quote Originally Posted by nuclearlaser View Post
    NO !
    At present, a maximum of 3 in the FRONT & 2 in the REAR is permitted w/ the current system.
    (This could change in the future.)
  11. #60
    Nov 2016
    RedRocket, thanks for the fast reply. I am a long time user of LI HP, and have had all four sensors on the front of a camaro for years and never ever had a punch through at any range or side angle, and upwards shots. That was a total of 8 lasers emitting during an encounter. Some may say overkill, but not really. I bought a new camaro and want a setup that will perform the same whether it is considered overkill by some. I am ready to purchase, and just needing some info before this happens. What would happen if all 5 were installed on the front?
