Results 1 to 10 of 67
Threaded View
    Important: Head Positions on your ALP Install.
    When installing a dual system you do not want to place the heads too far apart from each other (For example under each headlight) that is too far apart for sensors in a dual install. If you do a Triple install and have one under each headlight but also place one head dead center that configuration will work fine. Just realize its important that heads be installed in order when doing a Triple front install. (F1, F2 & F3) and the F2 head needs to be in the center position. Its best to also post photo's of your install and we will mark out suggestions for optimal placement. You can post your photo's in the ADVICE ON PLACEMENT thread. Its also a good idea to preview others installs before you install your own.
  2. The Following 20 Users Say Thank You to BestRadarDetectors For This Useful Post:
    991TurboS (05-18-2015), AirMoore (11-13-2015), Clint Eastwood (06-13-2015), curmudgeon (05-18-2015), dinkydi (05-18-2015), dmlgc (09-03-2015), ECMExpert (05-18-2015), EightyFiveHundred (05-18-2015), Hyper (07-29-2015), lugnuts (05-18-2015), Magn3t1cSt0rm (07-05-2015), modsl55amg (05-19-2015), PAPACUCU (06-15-2015), prowler793 (05-18-2015), Qui-Gon (05-18-2015), Radarrob (05-18-2015), Tman (05-18-2015), V1Jockey (08-02-2016), Vortex (05-18-2015), wirelessandy (05-18-2015)
