Results 1 to 8 of 8
    May 2015
    Sensor Coverage & Range
    Hi, I am new to site and looking to get the ALP on my car but can't decide on 4 or 5 sensors.
    What is the coverage radius from 1 sensor? how low or high (measurement) can I put the sensor to get max coverage? How far can it detect threat?
    Thanks
    Senior Member tawwwd's Avatar
    What kind of vehicle is it?
    typical car and small suv only needs 2 on either side. larger suv and trucks would be safer to go with 3 front 2 rear.
    You get about 18" coverage on any side of the sensor. sensors should be no more then 36" apart.
    detect distance depends on the incoming source - the alp will detect at any distance as long as there is a source. (most typical lidar guns are only good to 2000 feet, except newer VPR guns exceed that range)
  3. The Following User Says Thank You to tawwwd For This Useful Post:
    modsl55amg (05-12-2015)
    Post up a picture of your car, that will tell us alot
    May 2015
    The city I am in,like to hide on top of bridge and aim at the rear end of vehicles. That's why I was thinking either "red" or "blue" placement. Or any recommend placement?
    Quote Originally Posted by alanchm View Post
    Red on Front, & Blue on Rear should serve you well.
    Have the Receiver "bubbles" on the in-board sides on both Front & Rear. The Lidar guns used in your area have a range of 6000ft. if you're located where I think you are.
  7. The Following 2 Users Say Thank You to RedRocket For This Useful Post:
    modsl55amg (10-10-2015), tawwwd (05-13-2015)
  8. #6
    X2... Those locations will serve you well.
  10. #7
    May 2015
    Thx guys
  11. #8
    Haha...It's well known around here
    There are lots of guys from Edm on here already if you need help with it... Agreed on the red front/blue rear placement.
