Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: Alp ???
  1. #21
    Quote Originally Posted by Davek View Post
    Yay! I got my multi-purpose parking system today!! Thanks Tom!
    So whats the point about making sure the sensors are level??
    I hope you're just kidding w/ us making that statement !
    Failure to do so nullifies performance & guarantees you'll be getting many speeding citations. Post #18 above may be a wise option for you to take so the Wife doesn't see & start asking questions about what/where those "things" came from.
  2. #22
    http://www.ukspeedtraps.co.uk/speed1.htm
    check the angles then u will know
  3. The Following User Says Thank You to dinkydi For This Useful Post:
    RedRocket (05-12-2015)
  4. #23
    May 2015
    Got it! Thanks.......I forget this device is active not passive like a radar detector
  5. #24
    May 2015
    I finished the install of the front sensors and have found out how to get thru firewall last night. So I'm super excited to work on this all day and hopefully get it up and running.
  6. The Following 5 Users Say Thank You to Davek For This Useful Post:
    beingaware (05-16-2015), dinkydi (05-16-2015), Qui-Gon (05-16-2015), RedRocket (05-16-2015), Tman (05-16-2015)
  7. #25
    May 2015
    Ugh... what a long day running wires. But it's done and alive. I am confused about the Bluetooth box. I'm sure I could read more but have to ask. Does it plug in between control module and C or just in place of control?
    Here's few pics. Long day for me. I haven't work this hard to run wires since Led Zeppelin existed And that little yellow flourescent level tortured me all day.
    This is showing all the wires going thru the firewall. There was a plastic tray running the entire length of the floor pan so I ran wires there instead of thru car.
    Just a ton of wires too but they all got tucked away.
  8. The Following 2 Users Say Thank You to Davek For This Useful Post:
    dinkydi (05-16-2015), Tman (05-16-2015)
  9. #26
    You connect either the controller or BT module to the C port.
  10. #27
    May 2015
    Got it! Thanks!
  11. #28
    Where did you go through the firewall in your R?
  12. #29
    looks like around the brake servo ,if the vw was similar to the audi, if u went to the fuse block /ecu, u could unclip the ecu and that gave a large opening to see inside of the car, once removed, either left or right side of f/wall under the bonnet
  13. #30
    That's the route mine takes dd but damn the noise sneaking in.
    Oh wells will be sorted out soon.
