I thought automotive is supposed to go higher...much higher.
http://www.aecouncil.com/Documents/A...e_Document.pdf
The 4 grades for automotive electronics are on page 9 of the PDF, which is marked "page 3 of 42". This isn't something that's designed to be installed in the engine compartment, but even grade 3 goes up to 85°C or or 185°F.
I am concerned about what's going to happen if you're parked in Las Vegas or Phoenix during the summer. Even if the control set is installed in a shaded location, the interior temperature of a car can easily be 30°F warmer than the ambient temperature, and the ambient temperature in those areas can get up to 115-120°F.
