Results 1 to 10 of 40
    Senior Member CJR238's Avatar
    Dec 2013
    CT
    Quote Originally Posted by Jaypm777 View Post
    So I guess I should buy two sensor extension cables for the rear sensors?
    I only mention the cable extensions because it was such an issue on my hatchback making custom extensions on the spot. And though my TL is much longer since it has a trunk it shouldn't be as bad. But definitely measure from where the CPU to the rear trunk accounting for hiding the wires and you will have an idea if the cable is long enough. Using a long string will give you a better idea.
    There should be a cover above your feet that can be removed and the ALP CPU can be placed there then run the cables back for the rear head. My old ZR4 rear had a very long cable compared to the ALP and so I had no issues. There should also be a grommet above and to the left of the break peddle where the front head wires can be slipped through the fire wall.
    I am going to run a dedicated phone for the BT connection, it communicates the information and info better.
    "trust, but verify"
  2. The Following User Says Thank You to CJR238 For This Useful Post:
    dinkydi (04-14-2015)
