If you go to the trouble of doing a rear install, you might as well do the wiring for two heads, since it is (in most cases) such a (dis-assembly/reassembly) )project. You don't want to do it twice (unless you're really bored and have a lot of time to kill ;-) )
As Rob ^^^^ mentioned, it depends where you drive.
The Following User Says Thank You to curmudgeon For This Useful Post:
- You may not post replies
- You may not edit your posts
Forum Rules
