Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
    Junior Member Jaypm777's Avatar
    Apr 2015
    Lubbock, Texas
    Looking for advice before purchase of ALP.
    I have an Acura TL (2006) I only have a Escort 9500ix with Escort live. Haven't decided on 3 or 4 ALP sensors (2 in front, 1 or 2 in back). Not a lot of options to mount 2 due to the way the trunk lid is made. Looking at getting the Bluetooth module and possibly the GPS module. Also I was curious on what price I should expect for having it installed on this car. Any ideas or help anyone could give would be much appreciated. TIA
    The 9500ix seems to work good on X, K and Ka bands but of course it's not great on laser. Would this detector work ok in conjunction with a ALP system?
    Senior Member tawwwd's Avatar
    no point in doing 1 sensor in the rear. at least 2 per side to protect you. your trunk lid is fine for 2 sensors. lots of people do it with similar ones. personally i would just get the hifi kit and not worry about the BT or GPS part.
    Its super easy to do yourself but a good install will be a few hundred dollars.
    No radar detector should be used for laser really because if its getting an alert on laser they already have your speed and youre toast anyway. with the ALP its not needed.
    here is the best place to mount the sensors on your car in red
Size:  127.2 KBName:  5548023643_508151339e_z.jpg
  3. The Following 3 Users Say Thank You to tawwwd For This Useful Post:
    curmudgeon (04-14-2015), dinkydi (04-14-2015), Jaypm777 (04-14-2015)
    ^^^^^What tawwwd Said^^^^^^ 2 Front/ 2 Rear and go with the HI-FI set, the speaker is very loud and everything is out of your way, it will give you detailed report on front/rear hit and what gun is being used!
  5. The Following User Says Thank You to Holla For This Useful Post:
  6. #4
    What's your location? Not all states shoot in the butt.
    Telling the truth and exposing the lies in the lidar and radar industry
    "I'm interested to see how well you do.I never seen a car JTG before would be a first for me.."
  7. The Following User Says Thank You to Radarrob For This Useful Post:
    CJR238 (04-14-2015)
  8. #5
    Land of taxes
    If you go to the trouble of doing a rear install, you might as well do the wiring for two heads, since it is (in most cases) such a (dis-assembly/reassembly) )project. You don't want to do it twice (unless you're really bored and have a lot of time to kill ;-) )
    As Rob ^^^^ mentioned, it depends where you drive.
  9. The Following User Says Thank You to curmudgeon For This Useful Post:
  10. #6
    Apr 2015
    Lubbock, Texas
    Quote Originally Posted by Radarrob View Post
    Lubbock, Texas.
  11. #7
    Apr 2015
    Lubbock, Texas
    Quote Originally Posted by tawwwd View Post
    Thanks a lot for the pics! I was gonna just put one in the back right above the LP, I thought the area would be to small for two sensors. If two there cover better than one then I'll go with two. So you guys saying no to the BT module don't use the ALP connect app on the iphone?
  12. #8
    You NEED 2 heads in the rear of any vehicle, One will not protect you enough. We are not saying not to use BT, I have both and love both but you can only use one at a time and as of now I prefer the HI-FI set up so I dont have to rely on my Iphone! The BT module works great.
  13. #9
    Senior Member CJR238's Avatar
    Dec 2013
    CT
    The TL's are great for jammer set ups, my 9500CI install here may give you some ideas: http://radarandlaserforum.com/showth...-9500CI-review
    If you can spend the extra, 2 heads up front and 2 rear are recommended, but i did only put one head on my new Mazda 3 install: http://radarandlaserforum.com/showth...te-CJR-install since i never really get shot in the rear and i did it more for testing purposes. That rear placement tawwwd recommended should do the trick.
    My install shop (NY) by me doesn't charge much to install, but it can depend on how you want it installed. I would guess it should cost from $3-500. In my Mazda3 install which is a short car i needed to extend the rear head cable because it was too short so do some measurements.
    "trust, but verify"
  14. The Following User Says Thank You to CJR238 For This Useful Post:
  15. #10
    +1 for the two rear heads, fit and forget, even if they dont shoot u in the rear yet, that day may come, if you move to another area ur all ready covered
  16. The Following 2 Users Say Thank You to dinkydi For This Useful Post:
    CJR238 (04-14-2015), curmudgeon (04-14-2015)
