Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
    Junior Member Jaypm777's Avatar
    Apr 2015
    Lubbock, Texas
    Here is the 9500ix with escort live and I have a holder for my iPhone. So I thought the BT would be the way to go since I've already been using the escort live on my phone.
    GO VOLS DEEP!!!
    Apr 2015
    Lubbock, Texas
    Quote Originally Posted by CJR238 View Post
    The TL's are great for jammer set ups, my 9500CI install here may give you some ideas: http://radarandlaserforum.com/showth...-9500CI-review
    If you can spend the extra, 2 heads up front and 2 rear are recommended, but i did only put one head on my new Mazda 3 install: http://radarandlaserforum.com/showth...te-CJR-install since i never really get shot in the rear and i did it more for testing purposes. That rear placement tawwwd recommended should do the trick.
    My install shop (NY) by me doesn't charge much to install, but it can depend on how you want it installed. I would guess it should cost from $3-500. In my Mazda3 install which is a short car i needed to extend the rear head cable because it was too short so do some measurements.
    So I guess I should buy two sensor extension cables for the rear sensors?
    correct, bt works fine if u got the module, also may need the gps, but think the gps don't link up correctly as of yet but u do get the speed display on the phone, brd best for advice on gps though
  4. #14
    Senior Member CJR238's Avatar
    Dec 2013
    CT
    Quote Originally Posted by Jaypm777 View Post
    I only mention the cable extensions because it was such an issue on my hatchback making custom extensions on the spot. And though my TL is much longer since it has a trunk it shouldn't be as bad. But definitely measure from where the CPU to the rear trunk accounting for hiding the wires and you will have an idea if the cable is long enough. Using a long string will give you a better idea.
    There should be a cover above your feet that can be removed and the ALP CPU can be placed there then run the cables back for the rear head. My old ZR4 rear had a very long cable compared to the ALP and so I had no issues. There should also be a grommet above and to the left of the break peddle where the front head wires can be slipped through the fire wall.
    I am going to run a dedicated phone for the BT connection, it communicates the information and info better.
    "trust, but verify"
  5. The Following User Says Thank You to CJR238 For This Useful Post:
    dinkydi (04-14-2015)
  6. #15
    Apr 2015
    Lubbock, Texas
    Yeah, I'm really tore on what to get now. I guess I could just get the hifi for ALP and use the 9500ix and escort live for GPS and display. Would you suggest a kill switch or does the auto kill (after 4 sec I think?) work pretty good?
  7. #16
    Dec 2013
    CT
    Other than the beeping and blinking to communicate from the key pad its not bad alone. I'm holding out in hopes ALP makes the BT and key pad work together at some point. It still jams and communicates well with the key pad only. No need for a kill switch when a press of any button on the key pad kills the jammers.
    "trust, but verify"
  8. #17
    Not to conflict with CJ I run with a kill switch just personal find it better than tapping fone
  9. The Following User Says Thank You to dinkydi For This Useful Post:
    CJR238 (04-14-2015)
  10. #18
    Apr 2015
    Lubbock, Texas
    I assume your are talking about the BT and using AP connect on your phone?
  11. #19
    Apr 2015
    Lubbock, Texas
    Went ahead and put my order in for the ALP system with 4 sensors, Bluetooth module and 2 extension cables. I may try to sell my 9500ix with EL and get the AL RG module + STi-R plus reciever next.
  12. The Following User Says Thank You to Jaypm777 For This Useful Post:
    CJR238 (04-14-2015)
  13. #20
    Dec 2013
    CT
    Nope just the keypad only. I don't actually have the Bluetooth module yet.
    Sent from my XT1080 using Tapatalk
    "trust, but verify"
