A dealer that installs our product is also supposed to support the product and not let you walk out of the shop with a system that is not working properly. They should have installed the firmware and when you picked it up all you should have had to do was install a settings file to customize it to your preferences. Being that he is local to where you are at now, The ideal scenario would be for him to replace the CPU for you and as a dealer he should be stocking product and have a unit on hand locally.
When I sell a radar detector as BRD and it has a problem the customers will come back to me during the 30 day return period and its our responsibility to replace it for the customer and not the manufacture. If he calls the manufacture during this 30 day return period Escort (Just for example) would tell the customer to go back to the BRD and have them swap it out for a new one.
Your product does have a warranty and we will support you regardless but you are in a situation where the dealer should be able to help you locally. If you are moving 1000 miles away we can certainly work with you to get your unit replaced where you end up but you had a problem on a weekend where all carriers are closed and logistically there is nothing we can do to get you a replacement unit today.
