Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
    Question ALP Question please
    Hi Guys,
    A question please,
    Is it possible to unplug a usb from a live alp and instantly ( or nearly ) turn it back in to a parking system only with No Jamming?
    Cheers.
  2. The Following User Says Thank You to V8MBO For This Useful Post:
    modsl55amg (03-03-2015)
    Quote Originally Posted by V8MBO View Post
    Hi Guys,
    A question please,
    Cheers.
    You dont need a USB inserted to run it unless you installed a security key. Many people keep 2 USB Drives in their cars with different color USB Sticks with different settings. It only takes 1-2 seconds to load up a new settings file so yes you could switch back and forth relatively easy.
  4. The Following 2 Users Say Thank You to BestRadarDetectors For This Useful Post:
    modsl55amg (03-03-2015), Tman (03-03-2015)
    Cheers BRD,
    I see what you mean but what I am looking for is when the usb is removed the alp is instantly ( more or less ) turned in to a pure ( and thus legal ) parking system, ie no usb, no jamming so problems with the cops, the situation would be " Alarm goes off, I unplug the usb and hey presto, its a parking system, Instantly by just pulling and disposing of the usb " thus mr police man is none the wiser..
    see what I mean?
  6. The Following 2 Users Say Thank You to V8MBO For This Useful Post:
  7. #4
    Senior Member dukes's Avatar
    Alberta, Canada
    Cheers BRD,
    see what I mean?
    Your looking for Privacy Mode then, just note once you complete the process on your unit its permanent.
  8. The Following User Says Thank You to dukes For This Useful Post:
  9. #5
    Hi Dukes,
    Sorry how does that work then? I have LPPs just now and am moving to ALPs so its all new to me : ) sorry if I am asking dumb questions!!
  10. The Following User Says Thank You to V8MBO For This Useful Post:
  11. #6
    Alberta, Canada
  12. The Following 3 Users Say Thank You to dukes For This Useful Post:
    dinkydi (03-04-2015), modsl55amg (03-03-2015), Qui-Gon (03-04-2015)
  13. #7
    Alberta, Canada
    Remember you cannot turn this off once activated!!
  14. The Following User Says Thank You to dukes For This Useful Post:
  15. #8
    Cheers BRD,
    see what I mean?
    There are tons of features and options to customize the ALP almost anyway you want. Also realize that if used properly you will not really inform the officer that you are jamming them. By default the ALP will only defend for 4 seconds and then give them a reading. This is selectable from 3-9 seconds. Lets say you keep the default at 4 seconds and you are hit and immediately slow you can hit any button on the controller to instantly kill the ALP so that they will get a reading sooner and you will be less obvious. Once killed the ALP will go into parking mode for the next 60 seconds automatically before going back into defense mode. If for some reason you get pulled over you can keep a parking USB Drive in your glove box along with your insurance papers so you can switch the system into parking only at that time and not be obvious and suspicious.
  16. The Following User Says Thank You to BestRadarDetectors For This Useful Post:
  17. #9
    Quote Originally Posted by dukes View Post
    X2... There are plenty of features available to use before I would use a security key. There is no way to reverse this and if you do not backup your key and loose it you will render your system useless.
  18. The Following User Says Thank You to BestRadarDetectors For This Useful Post:
  19. #10
    Cheers Guys,
    I am aware of the shut off when hit as I have had jammers for years, But if the police spot the head units and then switch the system on and it jams I am in trouble,
    HOWEVER if they fire up the system Without the usb inserted and its Just a parking sensor I am fine, ie attached and presumably with this setting and no usb its just a parking system?
    great forum btw and very helpful, thanks!!
  20. The Following User Says Thank You to V8MBO For This Useful Post:
