Results 21 to 30 of 49
  1. #5
    South Jersey
    Once all the updates are complete (Will take around 6 minutes if you have HiFi) you will no longer need to keep the firmware files on the USB Drives. If you want to switch settings just keep a different setup.alp file on each of your drives.
    Tom/BRD/Members: What is the correct procedure to perform when using a USB Flashdrive (setup.alp) to change the CONTROL BOX settings?
    1. Do I leave the ALP system on, then insert the USB Flashdrive into the USB port, then remove the Flashdrive when the download is complete?
    2. Do I have to turn the system OFF, then back ON, after the new CONTROL BOX settings download is complete?
    3. Or do I just leave the system ON after the new CONTROL BOX settings download is complete?
    3. From everything I have read and viewed, with the ALP system ON, I would just insert the Flashdrive, with the new settings I want, into the USB port, the system downloads the data in a few seconds, I then remove the drive, and I do not have to do anything else. Is this correct?
    Thanks again for your help.
