Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 49
    Quote Originally Posted by V8MBO View Post
    Cheers Guys,
    I am aware of the shut off when hit as I have had jammers for years, But if the police spot the head units and then switch the system on and it jams I am in trouble,
    HOWEVER if they fire up the system Without the usb inserted and its Just a parking sensor I am fine, ie attached and presumably with this setting and no usb its just a parking system?
    great forum btw and very helpful, thanks!!
    You can also install the ALP GPS Antenna and the system will not fire back or defend if you are not driving over a set threshold.
    modsl55amg (03-03-2015), OrlNmE (03-03-2015)
  3. #12
    Very cool : ) so I can set it to xyz mph and it wont return fire!! While I have been very happy with the LPP these seem miles ahead : )
    Thanks again for your help guys.
  4. The Following User Says Thank You to V8MBO For This Useful Post:
  5. #13
    Senior Member dukes's Avatar
    Alberta, Canada
    Yep you got it
    Name:  alp parking.JPG
  6. The Following User Says Thank You to dukes For This Useful Post:
  7. #14
    Correct.. So lets say you set the LID Speed Limit to 24mph, It will only activate when you are traveling 25mph or more. If you are at 30MPH and hit and hit the brakes as soon as you reach 24mph it will automatically stop defending if you did not already kill it by the timer or pressing any button to kill it.
  8. The Following User Says Thank You to BestRadarDetectors For This Useful Post:
  9. #15
    Quote Originally Posted by dukes View Post
    Yep you got it
    That is the Parking Alerts settings.. He would need to set the "Define LID SPEED limit" setting.
    "Laser Interference Defense mechanism will not be activated unless you are moving at a greater speed than defined here; this option will be activated only if GPS-receiver is connected to the system."
  10. The Following 2 Users Say Thank You to BestRadarDetectors For This Useful Post:
    modsl55amg (03-03-2015), V8MBO (03-03-2015)
  11. #16
    Alberta, Canada
    You caught me while editing :P lol
  12. The Following 2 Users Say Thank You to dukes For This Useful Post:
  13. #17
    So just to confirm, if the alp is set to privacy and the Usb is in, its a jammer, Usb out and its only a parking sensor ?
    Thanks again.
  14. The Following User Says Thank You to V8MBO For This Useful Post:
  15. #18
    Thanks again.
    Its always a parking sensor but without the USB Key it will no longer go into defense mode... Once Privacy Mode is installed you also can not deactivate the feature so if you loose the Key File on that USB drive it will become a permanent parking sensor. I personally think you are better off using one of the many other options presented to you but the choice is yours.
  16. The Following User Says Thank You to BestRadarDetectors For This Useful Post:
  17. #19
    Your idea is very good , i guess the only way to achieve your goal is by using the security key , some use it without issues...just keep many copies of your code in many placesB-)
  18. The Following User Says Thank You to Tman For This Useful Post:
  19. #20
    Cheers Guys,
    I will just make LOTS of usb keys, for me its the best way, if the police here in the uk were to discover it was a jammer I would be in very deep 5hit indeed,
    This way if I get stopped or mr police gets too interested its just a case of pull and dispose of the usb key and nothing can be proven, even if he switches it on and off.
    Thanks again guys for your help, this is a great fourm : )
    Check this out as to what I mean .... http://www.bbc.co.uk/news/uk-england...shire-31604908
  20. The Following User Says Thank You to V8MBO For This Useful Post:
