Results 1 to 7 of 7
    NYB
    Thankyou BRD good see you still active on here !
    I found that the Firmware was using a old version and had a serial # issue after comparing stats and redoing the stats etc,
    I've updated to latest 4.5.2 firmware and control firmware has now been updated using the correct serial # and now Ive made a new setting USB incase the coding changed on the settings web page and maybe it was conflicting with the poliscan false alerts setting
    The filtering is very good for the ALP ,
    Ran it all summer with 0 false alerts
    I limit my set up to avoid it being found in case of vehicle search I'm running purely with the controller hidden and the flashing light aswell to avoid being busted, I use USb stick to change settings
    I'm sure the light sequence or sound is different for front and rear, Thanks I get out my lZ1 and hit it on the rear and see which sounds for front and which is for rear !
    Then this can narrow down if it's constantly coming from rear or front
    In my place residence these systems are illegal kind of depending if its ACMA or HWY Patrol that investigate , ( 904 is non restricted and in OZ must accept interference from other devices operating in same spectrum ) This is why I'm so discreet on my install the sensors scream out loud enough in the position they are mounted however not 1 fine never !!!!!
    I will post my results after runnig this for 1 week to be fair as I'm getting 3 to 9 a week ,
    Crossing fingers !
    Thankyou again BRD will take note of sound etc when hit the rear Vs front and yeah hope I dont get anymore!
    Have good day
    MelbVT
  2. The Following User Says Thank You to melbVt For This Useful Post:
    modsl55amg (02-27-2015)
