Results 1 to 4 of 4
    Jan 2015
    ALP Connect Question
    Sorry if this has already been answered -- I didn't see anything on the forum after a quick search. If you are installing ALP Connect and you forget your phone, is it possible for the system to still run? It would be a need feature, for the system to instantly jump into a default mode (4 seconds of protection, then silent) -- even though you wouldn't know it was happening (no alert).
    Thanks,
    JB
    Quote Originally Posted by jbeinhor View Post
    Thanks,
    JB
    No, But you can get a cheap switch box and use it to switch back and forth between BT & the standard controller if you forget your phone. If you are using BT and you dont have your phone the system will not go on since the BT would be acting as the controller.
    jbeinhor (01-28-2015), modsl55amg (02-20-2015)
    Jan 2015
    Thanks for the quick reply!
    Tom : Name:  LuckyLuke.gif
  6. The Following User Says Thank You to Tman For This Useful Post:
    curmudgeon (01-28-2015)
Tags for this Thread
