Results 1 to 10 of 10
    Jan 2015
    Cool Define LID SPEED limit & Define PDC SPEED limit settings?
    Hey Everyone with Alp's GPS. Just wondering what preferene everyone speed is set to? I prefer 6mph PDC & 12 mph.
    what ever ur preference u like, so peoples will vary
    Jan 2015
    Thanks
    You know, I just realized that another use for the ALP's GPS module could be to show an officer that you just have a detector but not a jammer. You could switch on the ALP, and invite the officer to shoot his gun at your car (while it's parked on the side of the road of course). Assuming you set a LID speed that's > 0, it'll just detect but won't jam, and you'd have "proven" that you aren't using a jammer, even if you lose your parking mode only USB key.
  5. The Following User Says Thank You to awj223 For This Useful Post:
    hussein (01-20-2015)
    Jan 2015
    Great info! Thank you. I was driving around today and left LID speed to 12. Works great LID is disabled while stopped. I did lose GPS signal a lot though. I installed GPS inside radio console. I wanted a clean install but guess not the best idea.
    Quote Originally Posted by ckaos1 View Post
    Put the GPS on top of the dash or put it under one of the thin plastic dash panels. If you mounted it in your dash your signal will definitely be compromised.
  8. The Following User Says Thank You to BestRadarDetectors For This Useful Post:
    ckaos1 (01-20-2015)
  9. #7
    What mode is it in when the car is stopped? Does it even detect LIDAR, or does it just do parking mode?
  10. #8
    Jan 2015
    Just on parking mode while car is stopped. Green LED's light up. I tested my remote laster tester and doesn't respond.. Works great. While parked in garage i do lose my gps and goes straight to arm mode.
  11. The Following User Says Thank You to ckaos1 For This Useful Post:
    awj223 (01-20-2015)
  12. #9
    FL
    Does the speed limit function work with android connect since it is using the phone's gps?
  13. #10
    No, For GPS Features you need a GPS antenna connected directly to the ALP.
  14. The Following 2 Users Say Thank You to BestRadarDetectors For This Useful Post:
    dukes (01-19-2015), FJR1300 (01-19-2015)
