Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. #21
    From what i read , the heads perform better
    when aligned horizontally in the same plane,
    as per Tom's recipe....hope i learned well :-!
    Correct.. Is there a space above the chrome bumper? Is so using a triple would work well using the same lower marked images but mounting 3" or so higher if there is an opening there.
  2. #22
    Sep 2014
    I had the same problem going through the grill and originally I used 3m Velcro to hold them in place. However for more stability, I created a bracket to mount the heads on. I hope the pics are visible and clear if not I can take a few more shots of them. Name:  ImageUploadedByTapatalk1417977462.377719.jpg
Size:  124.1 KBName:  ImageUploadedByTapatalk1417977479.614707.jpg
Size:  231.9 KBName:  ImageUploadedByTapatalk1417977496.255675.jpg
    LTI 20/20 (Truspeed)
    Stalker LZ1
    Passport Max2
    AL Priority 3 front 2Rear
    Escort live
    Waze
  3. #23
    Sep 2014
    Didn't take the 4th pic.
    Stalker LZ1
    Passport Max2
    Escort live
    Waze
  4. #24
    Sep 2014
    It's a bit messy looking but I have much more adjustments to make to it as well as needing to completely cover up all screws even though they are not visible outside of the truck. Bottom screws are just to hold bracket and I have top screws holding down the ALP bracket in place.
    Stalker LZ1
    Passport Max2
    Escort live
    Waze
  5. #25
    Quote Originally Posted by OrlNmE View Post
    Thanks for pics! That's a great idea
  6. #26
    Thanks Tman! I appreciate that you did further research on this.
  7. The Following User Says Thank You to ROCKEY For This Useful Post:
    Tman (12-07-2014)
  8. #27
    Thanks! I'll take that into consideration
  9. #28
    [QUOTE=ROCKEY;40679]Hey guys, I am new to this whole thread thing. I am looking for some feedback on the perfect placement of 3 ALP sensors on a Toyota tundra. I was advised 3 should be enough to cover the entire front however, not so sure it really covers the entire thing. I can't install between the grille as shown in the pic because it's part of the hood. I am thinking about installing them in a little crevice below the hood. My worry is not having coverage on the headlights since they will be installed lower. Any input would be helpful. Thanks [/Q
    Hey guys, any suggestions for 2 laser sensors, see pic
  10. #29
    FL
    Might want to black out your tag #.
    If that black piece that the the plate attaches too is all plastic, you could cut a slot just wide and tall enough for the ALP bracket to go through and a hole just big enough for the connector and bolt the bracket behind the bumper area. From what I've seen in testing most people seem to go with a sensor each side of the plate (18" apart iirc) and have good results as long as you don't recess the heads. I'm sure that one of the RALETC guys will pop into your thread before too long and let you know the best location.
  11. #30
    Thank you very much
