Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
    Feb 2014
    Gold Coast Australia
    Yep! Really thought 8.1 would fix and mine disconnects form blue tooth and I physically have to reconnect it constantly.
    Other Bluetooth issues connecting to car are ok now so possibly its on the ALP side that it's not being compatible with ios8?
    Or, it's still an issue on Apples side.
    Who knows!
    re loaded the app set privacy , checked alp set for always, no where near the car , so did a scan found nothing to connect to, went straight back to privacy and alp, always on , had gone ,so the phone dont need to connect to the bt in car to drop out,
    all the other apps in my phone that use the privacy thing gps etc, show in the settings always and stay there, just the alp app that loses it , makes mi think is it the app that aint caught up with they latest ios 8.1
  4. #14
    Connecticut
    I have got so quick now, starting the ALP app then going back to the settings to redo the privacy settings. It's like 2nd nature.
    PowerUCC Panorama G DashCam
    --> RALETC TESTED! <--
    Install
    Prius_C_Install
    Testing
    April_4_2014
    April_13_2014_RALETC_MEET
  5. #15
    waiting till its fixed as i get in and out of the car a lot , the annoying thing is the bt module is working fine and changes at the the set kmp/h into defence ok just shows Zero, seems to be taking a long while to fix, as i mentioned the only app to have this problem
  6. #16
    I am trying to get AL to just use the attached GPS for speed instead of the phones GPS if one is attached. It will help solve the Apple issue for several of us that use the attached GPS. It would also enable speed for those that want to use iPods with no GPS.
  7. The Following 2 Users Say Thank You to BestRadarDetectors For This Useful Post:
    Abarth695 (10-27-2014), dinkydi (10-26-2014)
  8. #17
    Just downloaded 8.1.1 Will let you know.
  9. #18
    Dec 2013
    Tried location services on 8.1.1 with 5s still no joy 😟
  10. #19
    Junior Member HOiYA's Avatar
    Sep 2014
    SF Bay Area
    I wonder if the issue is that the ALP app manages the BT connection through the app and not through the iOS settings tab. I say this is because the ALP doesn't shop up as a paired device even when it is not connected. If the OS isn't aware of it, it possibly can't remember the location setting for the ALP Connect? Just my theory.
  11. #20
    Uploaded 8.1.1 today, and so far, so good!
