Right : the green is negative trigger , the blue should work also w by changing the input on the timed relay...cant comment as i never used the blue.
In my setup , the green goes to negative under alert , it triggers the timed relay + the second relay via the the closed contacts , but after the set delay those contacts open thus change the second relay.
From there you can manipulate whichever action you want : close\open any circuit.
- You may not post replies
- You may not edit your posts
Forum Rules
