Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 60
  1. #31
    Sep 2014
    Midwest
    I take it the outputs have been revised on V2 to allow direct connection (negative trigger) with a standard 12v relay?
    2003 540i6: ALP Dual, Escort Smart Radar / Escort Live, Valentine One
  2. #32
    Quote Originally Posted by ApexOnYou View Post
    Please note the following wiring for using the Relay switch on V2 CPU's. Do not try this on the original V1 CPU's.
  3. The Following 4 Users Say Thank You to BestRadarDetectors For This Useful Post:
    ApexOnYou (06-23-2015), modsl55amg (07-03-2015), Redmoto (06-22-2015), Tman (07-05-2015)
  4. #33
    We discussed this before ;
    http://radarandlaserforum.com/showth...ll=1#post25378
    The relay I have is switched by +5V TTL logic on the green wire, and draws no more than 20 mA. Works fine on a V1 CPU, although the external load I'm driving is small
  5. The Following 2 Users Say Thank You to winterbrew For This Useful Post:
    dinkydi (06-22-2015), Tman (06-22-2015)
  6. #34
    May 2015
    Update: Midex relay is unavailable. Digi-Key has suggested this relay PB682-ND
  7. #35
    May 2015
    Warning on green wire
    WARNING #2
    If you forgot the stand alone diode you will MELT/FRY/BLOW your CPU. Or worse if you purchase the diode and install it backward you will fry your CPU ver2. And finally if your solder breaks on your correctly installed diode mths/years later you will fry you CPU....
    Bottom line for me I am using the blue wire. Good riddance to the green wire for now. Hopefully down the road ALP makes the green wire simpler/more robust to use.
    Name:  Green wire with stand alone diode.JPG
  8. The Following User Says Thank You to Redmoto For This Useful Post:
    Tman (07-05-2015)
  9. #36
    or you purchase one of these
    i have tried and tested this unit to switch things on and off on allert they work a treat
    http://www.ebay.com.au/itm/Band-New-...item33a3f0cdf7
  10. The Following User Says Thank You to deano For This Useful Post:
    Tman (07-05-2015)
  11. #37
    May 2015
    deano,
    yes that is what I will be doing on the BLUE wire (radio mute).
    Here is a Hong Kong vendor with nice chart at the bottom of the ad explaining all the connections.
    I like this one better because it has screw terminals for the wires too.
    http://www.ebay.ca/itm/400786093705
    Tman has found the china version 1/2 the price of the Hong Kong version, maybe the Hong Kong ships faster...
    http://www.ebay.com/itm/1PCS-DC-5V-D...item51cde3025f
    I ordered both !
  12. #38
    May 2015
    Indicator lights on relay helpful
    deano,
    on further reflection, your version has nice indicator lights....red & blue for power and switching probably.
    Question, where do I get those three veritcal post PIN connectors (female) for incoming power....?
  13. #39
    May 2015
    deano, yours does NOT include a timer, so I am back to Tman and my version.
  14. #40
    Quote Originally Posted by Redmoto View Post
    deano,
    I ordered both !
    sorry mate the relay i was meaning to show also has screw connectors i just used the first picture i came across on ebay
    mine dont have a timer the ALP cpu is the timer or the kill switch on the ALP,,,
    here is a picture to give some scale on there size
  15. The Following User Says Thank You to deano For This Useful Post:
    Tman (07-05-2015)
