Results 1 to 10 of 60
  1. #5
    Sep 2014
    Midwest
    What car are you installing this on? I know with the BMW "telematics mute" radio wire the ALP works fine without isolation. If you are concerned just throw a diode on the trigger wire - stripe side towards the ALP ground output. Much easier than a relay.
  2. The Following User Says Thank You to ApexOnYou For This Useful Post:
    Krus8r (09-24-2014)
