Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Sep 2014
    Midwest
    Thanks for the input, I will take a razor to the goober in the upper left so it isn't a noticeable eye sore.
    Gwinnett Ga.
    IMO, I would replace it, but would conceder using it as a 3 head in your setup, if you have a 2 head setup and get it tested out.
    Quote Originally Posted by Nicholat View Post
    Seriously dont use it. If you can get insurance company to replace it do it. There is no telling what internal damage was done to the head being dragged and having it bouncing around on the ground. It might fail if it has not failed when you need it the most. I would not trust it even if it was in perfect cosmetic condition.
    Radarrob (09-23-2014)
  5. #14
    Sep 2014
    Midwest
    Not even as a third head?
  6. #15
    Quote Originally Posted by ApexOnYou View Post
    Every head in a setup plays an important role since they all communicate with each other. You need to depend on each head and if one fails if hit with a VPS Gun that one head can have an adverse effect on all the others.
  7. The Following 2 Users Say Thank You to BestRadarDetectors For This Useful Post:
    curmudgeon (09-24-2014), Tman (09-23-2014)
  8. #16
    Sep 2014
    Midwest
    Ok that makes sense now.
