Seen many ask about dimming their remote LED so I thought I would make a how to guide. This will obviously void your warranty on your remote LED, but the remote LED can be purchased from BRD.
I used this controller I purchased off Ebay for 2$. http://www.ebay.ca/itm/12-24V-Mini-I...f683b86&_uhb=1
Note there are 6 wires. When I cut the LED cable, I gave my self plenty of room in case I messed up.
On the LED controller you will note that one side says "+LED-" and the other says "+12v-". Black wires are ground and red are positive.
Connect the YELLOW wire to the controller's positive cables. Note that it must correspond to the controllers "+LED-" and "+12v-". So obviously the cut cable with the rj11 on the end goes to the "+12v-" and the cut end with the LED to the "+LED-"
Connect the BLUE wire to the controller's negative cables. Note that it must correspond to the controllers "+LED-" and "+12v-". So obviously the cut cable with the rj11 on the end goes to the "+12v-" and the cut end with the LED to the "+LED-"
After that, solder your connections and shrink wrap it up nicely
You are now all done!
You'll notice that the only LED color that is dimmer is the blue one. The rest are still the normal brightness. Which is nice since the blue is constant.
