I had tree false alerts with alp quad system lately and was wondering if you guys knew whats causing the false alerts or how to correct it. Nothing has change since it was installed and when I got the alert there was a old Toyota behind me and a ford f150. I Also noted that the led change from red to yellow on alert. Should I consider restoring the device to factory defaults?
Than you for your help!!
Connect With Us
