Thanks BRD!
Thanks BRD!
I received a PM asking if I could share what the problem was and figured it would be a good idea to post the full answer for anyone else with this error if they are searching the forum.
There were actually two error codes going off here. If you use ALP Connect you will get a detailed description of the errors which makes it easy to diagnose and once the WiFi is released the system will give verbal warnings which will greatly help in troubleshooting. The warnings here were "GPS Antenna Disconnected" & "Radar Antenna Disconnected".
The customer had both options enabled in the setup file but neither were connected to the ALP. Once the settings file was corrected with both no longer activated the system there were no longer any errors.
