Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 80
Thread: Stinger Vip
  1. #21
    You would think so but I think they have 2 power settings going by the manual. I believe its on low power when they are on rear attack, plus the rd is less likely to pick up the beam until last moment.
    Be interesting to see how the stinger plays against the ddm.
  2. #22
    Yep sure will, doing a few k, s over next few month ob the plus and St both running
  3. #23
    Stinger Installed whoohoo, need some help how to get a pic from mi i phone, pm wb see if he can ?
    Added dinky - cheers WB
    cheers mate done one run kwikie only shop fronts showing on plus and chirping, nothing from S, so i presume setting band k is set within the limits
    Done a bit of checking on setting there is adjustments for sensitively and extra distance warnings. No settings for band seg, KA or K. pre loaded by the looks of it and automatically recognizes which state Ur in , looking into that with RH
  4. The Following 2 Users Say Thank You to dinkydi For This Useful Post:
    beingaware (07-28-2014), busta (07-28-2014)
  5. #24
    How you finding your new toy?
  6. #25
    Ain't been out yet, changed the settings to high sensitivity and broader band spread, also there is an interesting sec in the install man for the low power in Europe u turn the ant to a 45deg angle, if u look 0n there Web site Vip install
  7. #26
    Looks like its for MultaRadar CD (MRCD) ;
  8. #27
    Yep that's the one, I was just thinking it adds more thought to when ba turned his vertical
  9. #28
    Yeah, the MRCD is a strange beastie though (I think the V1 detects it as multiple bogeys on k band)
    I think the Gatso and Redflex are more conventional though, just polarised in one plane and low powered.
    The Stinger's patch antenna is supposed to cope with horizontal / vertical polarisation with no issues, so MRCD must be different
  10. #29
    Good thinking, Circular may be,
  11. #30
    hmm...
    I'm just speculating here, but looking at the patches themselves, and the way they're rotated 45 degrees, it almost looks like they're designed for linear polarization and rotating them 45 degrees so that they're a compromise halfway between vertical and horizontally polarized sources.
    I believe the Multanovas are vertically polarized so it looks like they're simply rotating it another 45 degrees to help with detecting it, at the cost of diminished horizontal polarization performance.
    Just a guess.
  12. The Following 2 Users Say Thank You to Vortex For This Useful Post:
    dinkydi (07-29-2014), winterbrew (07-29-2014)
