Results 1 to 6 of 6
  1. #4
    I assume the spread is pretty wide , i will try to find a lens to concentrate the ray.
    The tester is made to use close , i thought 20' would be the maximum ...that is why i am
    amazed with 60'
    I wonder if this laser diode could be retrofit in the tester , and give some increased distance ?
    SPLP90
    http://www.ebay.com/itm/SPLPL90-3-Na...item2c7b445fad
    I'm pretty sure the testers use a LED not a laser diode, but regardless they could be retrofitted. It may require a separate driver circuit to handle the higher power laser.
  2. The Following 2 Users Say Thank You to Mirage For This Useful Post:
    Qui-Gon (06-15-2014), Tman (06-15-2014)
