Results 1 to 6 of 6
    Pick-up Distance with Tester
    I dont have a real laser but thanks to Dukes i can use the Li tester recieved as a gift
    Today i was surprised to trigger an alert from 60' , anyone has measured this ?
    Senior Member oddpedestrian's Avatar
    North Carolina
    my biggest concern is how narrow and strong the beam is. I also walk it from one end of my headlight to the other to ensure the whole front end is protected. I dont get the greatest results from standing on my porch and shooting down simulating overpass shots.
    LEOOOO's come out to plaaaaaaayyyyy.
    BYE BYE LSP HELLLOOOOO ALP
    REDLINE REDLINE REDLINE, CAN NEVER GO WRONG WITH A REDLINE.....BY THE WAY DID I TELL YOU I HAVE A REDLINE?
    WAZE
    PRECEDENT DETECTORS:
    9500ix
    VALENTINE 1
    WHISTLER CR90
    I have not measured it, But i can tell you using the tester on the LI and The ALP, Alps will alert way way out compared to LI, also ALP, I didnt have to work as hard to get them to go off like i did with LI
    I assume the spread is pretty wide , i will try to find a lens to concentrate the ray.
    The tester is made to use close , i thought 20' would be the maximum ...that is why i am
    amazed with 60'
    Quote Originally Posted by oddpedestrian View Post
    I wonder if this laser diode could be retrofit in the tester , and give some increased distance ?
    SPLP90
    http://www.ebay.com/itm/SPLPL90-3-Na...item2c7b445fad
    North Carolina
    I guess I wasn't the only one I had to do the same with my lsp. It did let me know that my heads needed to be more leveled to properly "shift."
    WAZE
    9500ix
    VALENTINE 1
    WHISTLER CR90
  6. #6
    amazed with 60'
    SPLP90
    I'm pretty sure the testers use a LED not a laser diode, but regardless they could be retrofitted. It may require a separate driver circuit to handle the higher power laser.
  7. The Following 2 Users Say Thank You to Mirage For This Useful Post:
    Qui-Gon (06-15-2014), Tman (06-15-2014)
