thanks fletch
but like my self has 5 sensors on the rear I had front 3 ports left side and rear ports right side all on the rear
on some tests meets I noticed some probloms if I was to aim at the rear right tail light them pan to the left I would get PT as the rear(right heads) heads seen the lidar first looks like the heads that see the lidar first come priority
I had to mix ports around so right become left and left became right to set off a chain reaction so all heads fired together
having front heads on the left and rear ports on the right is ok if the shooter was to be pulling new trigger pulls ..but for those lidar guns that can track no need to pull a new trigger best to mix the ports around
