Results 1 to 10 of 67
Thread: "Error 2"
  1. #21
    That is good point and I was not even considering this. What switched circuit are you currently tapped into? Is the radio fuse switched power circuit?
    No I dont believe the radio is switched on this vehicle. I have used two different power sources . I am not sure what the other one was but the issues have occured on both.
    The one I am using now is :
    F39 5A* Daytime running lamps and headlamp control module ignition feed
  2. The Following User Says Thank You to kasher1979 For This Useful Post:
    modsl55amg (02-20-2015)
