Doubt that is the issue. We are making some changes to the firmware and most likely since its happening in the same location only when the sun is up its most likely interference. In Pre-Release versions we used to have a sun interference alert but even during sun interference the unit would still defend since the ALP automatically adjusts for the sun. The alert should not be an Error 2 when there is an interference error so it will be changed to an interference alert and we will lower the sensitivity of the warning after startup. In the latest versions we increased the sensitivity on start-up when it does a full sensor check but did not reduce it back after start-up.
