Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    I have the kill switch and as i have said before.. When i get painted with laser all i do is flip the switch... I have many apps running at the same time and waze is on the main screen and E/L, pandora and the B/T for ALP running in the back ground. so i dont have to take my eyes off the rd to kill.
    This for me is just easier and i feel more comfortable doing it this way, everyone has there on opinion and feelings..
    If you have the control pad and do not like to look of it just put it up in the visor area so you can hear it and dont really have to see it and then just add a kill switch..and done
  2. The Following User Says Thank You to kimberdan For This Useful Post:
    modsl55amg (03-15-2015)
  3. #12
    May 2014
    Yeah this is probably what I'll do I imagine
  4. The Following User Says Thank You to Imatk For This Useful Post:
  5. #13
    Google how to wire up a 12v relay with switch. Or buy one off eBay.
    Sent from my GT-I9505 using Tapatalk
  6. The Following User Says Thank You to beingaware For This Useful Post:
  7. #14
    Cant you just fit a switch to the power supply wire? That's what I have done with the LPP and older systems, that way if you get a hit you just check your speed and when your doing the correct speed switch the system off?
    Also can you not fit the hifi attachment so you have a speaker that way you can hide the controller out of sight and no one is any the wiser if they look in the car, say in the glove box or ash tray,
    And if you see my other post all I would need to do get the usb key and remove it to disable the jam cycle, a nice parking system : )
  8. The Following User Says Thank You to V8MBO For This Useful Post:
  9. #15
    Indeed for me the perfect set up,
    1/ control unit hidden
    2/ hi fi so a nice loud speaker
    3/ the usb key in a handy place to pull / remove in a hurry if required
    4/ a power switch out of sight
    5/ the led mounted in line of sight.
  10. The Following User Says Thank You to V8MBO For This Useful Post:
  11. #16
    May 2015
    If you are using the AL Priority as a laser blocker, you can simply remove the USB key and it will switch back to parking sensors???
