Alright found a fix for a feature I just requested lol. So the reason you cannot hear alerts from the ALP Connect app while listening to another source is because ALP is using an A2DP audio connection for the apps alerts. Waze is able to override the vehicles source ( XM radio, FM radio, CDs ) due to the fact it uses Hands-Free Profile instead. Which works just as if you were receiving a phone call via BT while listening to the Radio.
This little app called A2DP Blocker will block the A2DP Bluetooth Stereo Profile.
I have just tested this while tuned to FM radio and to XM radio. The alert from ALP connect will override the vehicles source and play the alert!!
Keep in mind, if you wish to switch back to BT audio you will need to disable the A2DP app to allow the phones music to play.
- Dukes
