Results 1 to 10 of 12
    Does the ALP phone app tell you what Lidar gun you are being targeted with?
    (YES)
    If your using your device to play music bluetoothed thru your car audio will an alert interup the music to alert you?
    (YES)
    What if you forget your device or battery goes dead, will the ALP revert back to giving you the alert tones thru the controller automatically?
    (NO) You can only connect one or the other or get one of the RJ45 Switches that several users are using to switch back and forth. See this thread: http://radarandlaserforum.com/showth...Control-Module
  2. The Following 5 Users Say Thank You to BestRadarDetectors For This Useful Post:
    curmudgeon (04-25-2014), FJR1300 (04-25-2014), hirevn (04-25-2014), kimberdan (04-25-2014), Tman (04-27-2014)
