Page 7 of 7 FirstFirst ... 567
Results 61 to 69 of 69
  1. #61
    melbVT is this with your Sti-R head connected to your ALP or to the CPU of your STi-R unit?
  2. #62
    good question there dragons, awaiting the answer !!, will be interesting, never made any changes to my antenna and running the latest fw, i would say the diff between , full plus sytem running ,or the ALP BT, is negligible , but having seen the difference in ba vids, some thing has changed to cause that short warning when mounted verticle
  3. #63
    I need to find one of those 4wd ones. They are so low powered it will be the most perfect test...
    Sent from my GT-I9505 using Tapatalk
  4. #64
    Will text you when I next see one
  5. #65
    NYB
    Sorry 4 late reply
    Mine is into my Stir+ as sadly the amount of False alerts where they park these low powered cameras whether they use a VE station wagon a newer mitsubishi outlander or a hidden old ford eco van!
    Try testing her horizontal here a pic of where mine is hence its behind mesh no drama picking anything up
    My car is known to 1 camera operator and its funny when I go past he stops his device if he notices me! Othertimes when he doesn't notice me I get tagged 24.166 or 24.100 by those low powered cameras ,
    Would anyone like me to plug her in to the ALP and compare my results I can find 1 today we have facebook group where it has 92K members in Victoria and we post rbts sherif flash 4 cash etc
    I have some spare time over next few days!
  6. #66
    Yep good idea, to see if any diff, with redflex
  7. #67
    You guys running gatso in Vic still or moved to redflex?
  8. #68
    NYB
    Gatso and red flex! They like to confuse us down here B.A,
    I found it depends on your antennas height
    By chance can you place yours round same height as mine?
    Why not run 1 vertical low on BA and 1 vertical high on dragons and go threw test same time then do same horizontal low etc etc
    This will give you a clear result to see if the height helps,
    My Bel stir+ tends to alert every time, I can show u a video of Gasto low powered in my stir+ Great detection up a hill in traffic with black suv in front of me reducing the chances of caching the alert
    http://videobam.com/ulbMb The volume reduces on my stir+ Listen u hear the alert !
  9. #69
    Mtd low pick signals bouncing underneath, so to me it 's high like a roof rack, or low
