Results 1 to 10 of 69
    Phased Radar behaves differently to door openers DD.
    CW Door openers pretty much spatter radar everywhere, and it can actually be pretty strong.
    Thus why our falses seem to remain.
    Where as phased LOW powered radars like the Redflex and Gatso 24 have beams that are focused in an area about the size of half a sheet of A4 paper.
    They are bloody hard to detect, and what ever has been "improved" to lower false detection has indirectly caused issues with detection.
    confused are you saying since the firmware or have there been some new gatso that is causing late detection,
    Im saying the new firmware misses the tight beam until its too late.
    Where as falses seem to be in the same spot.
    My 50mw gun has the same range it usually does but thats like comparing a concert speaker system vs some iPod ear buds (Gatso only put out about 0.5mw).
    Most door openers output about 50mw as well. :/
    http://docs.microwave-solutions.com/...php?id=MDU2400
    http://files.pepperl-fuchs.com/selec...t1903a_eng.pdf
  4. The Following 2 Users Say Thank You to beingaware For This Useful Post:
    dinkydi (04-21-2014), shanetrainST (04-21-2014)
    Member Antilaser's Avatar
    Croatia
    Can you email(support) or PM your setup file? To compare your results... Are you using an STiR-M antenna for those Low power 3D radars with MTR enabled?
    http://www.antilaser.info/
    Enjoy The Power Of Your Car
    Quote Originally Posted by Antilaser View Post
    The M edition head is only useful against Redflex cameras.
    The STIR+ head is fine against the Gatso24 cameras.
    The only thing that has changed is the firmware.
    Its gone from 700m to only 50m...
    Sent conf to you via pm.
  7. The Following 3 Users Say Thank You to beingaware For This Useful Post:
    dinkydi (04-22-2014), melbVt (04-22-2014), shanetrainST (04-22-2014)
  8. #6
    all new bel- plus cover the redflex k freq, the m has band seg mainly for EU ,
  9. #7
    We are using STI-R+ Heads. POP off, RDR off, TSR off & Segmentation K. The Gatso24 & Redflex are fixed frequency.
  10. The Following User Says Thank You to shanetrainST For This Useful Post:
    dragons (04-22-2014)
