Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 69
  1. #31
    aint done the fw upgrade yet been waiting for oz post, may put it in this morn minus the gps, but we have no set spc around here but can use the local super market, i know its not the best , and get back
  2. #32
    ok the first set file i download said .text ,cleared cache and all previous down loads did it again and then got the correct wording setup.alp,, and also used IE and that came out correct as well, so in they go, will know later this arvo
  3. #33
    so we can keep this in the oz sec, as it's only seems to be us ozzies speed cams, be easier to follow, noticed shane has just started , i will go out this morn and do a run
  4. #34
    posted in oz sec, found no diff on k, between bel plus, running separate, then changed over to alp bt, did three runs all the same
  5. #35
    Try it against a Gatso 24
  6. #36
    It's not mobile K we are worried about, but the flash for cash variety.
  7. #37
    Yep, the extremely low powered radar is the worry.
  8. #38
    you mean like the ones on the Bruce going North of Brisbane, nr Deception bay turn off where the weigh bridge is, or is there different ones you are meaning , like i said only super markets round me but the same one i go to every week, and the response is the same as the plus as ALP,
  9. #39
    what has lower than the slant mobile cruiser, which if far harder than the merc vans
  10. #40
    Dinky, forgive me for asking, but what does a supermarket have to do with detecting a Gatso? We get the same falses down here, that has not changed but Gatso detection has.
    When your down this way next let us know how you go with the FIxed Gatso's or a flash for cash on side of the road, be it a merc van or cruiser.
