Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 69
  1. #51
    Quote Originally Posted by Antilaser View Post
    Can you email(support) or PM your setup file? To compare your results... Are you using an STiR-M antenna for those Low power 3D radars with MTR enabled?
    The M edition head is only useful against Redflex cameras.
    The STIR+ head is fine against the Gatso24 cameras.
    The only thing that has changed is the firmware.
    Its gone from 700m to only 50m...
    Sent conf to you via pm.
  2. The Following 3 Users Say Thank You to beingaware For This Useful Post:
    dinkydi (04-22-2014), melbVt (04-22-2014), shanetrainST (04-22-2014)
  3. #52
    We are using STI-R+ Heads. POP off, RDR off, TSR off & Segmentation K. The Gatso24 & Redflex are fixed frequency.
  4. The Following User Says Thank You to shanetrainST For This Useful Post:
    dragons (04-22-2014)
  5. #53
    STI-r head here too, my setup file will be attached to this message, just rename it to Setup.alp as the forum will not allow .alp files to be attached.
    K is segged to 4 and 5.
    Setup file: Setup.txt
  6. The Following User Says Thank You to dragons For This Useful Post:
  7. #54
    all new bel- plus cover the redflex k freq, the m has band seg mainly for EU ,
  8. #55
    NYB
    I run the beltronics Stir+ I obtained it from DCG in March 2013
    It goes right down to K23.950
    The stir+m is this useless against some cams here in land of OZ!
  9. The Following 4 Users Say Thank You to melbVt For This Useful Post:
    beingaware (04-22-2014), dinkydi (04-22-2014), dragons (04-22-2014), shanetrainST (04-22-2014)
  10. #56
    Quote Originally Posted by melbVt View Post
    cant say, if as they advertise better for low power stuff on the M, is marketing hype, but if all that hype is about the lower freq they all have that, seg k here in OZ can be a bit tricky, i think the ALP with bt and gps is better, due to being able to isolate k freq to what sp you like
  11. The Following User Says Thank You to dinkydi For This Useful Post:
  12. #57
    Has there been any further development on this issue?
  13. The Following User Says Thank You to dragons For This Useful Post:
    dinkydi (04-29-2014)
  14. #58
    do fish swim
  15. #59
    Running the older firmware now.
    Detection is back to normal on it.
    Working with AL to find the cause of the change in detection.
  16. The Following 4 Users Say Thank You to beingaware For This Useful Post:
    dinkydi (04-29-2014), dragons (04-29-2014), shanetrainST (04-29-2014), winterbrew (04-29-2014)
  17. #60
    NYB
    Good 2 see someone solving the problems B.A Seems like Antilaser need to buy themselves a redflex and a Gatso to test it,
    When I went past the local speed camera van mounted down low vertical slightly on 45 angle I got 200Mtrs on highway mode and when I went though the sets traffic lights I got every Traffic signal frequency and was prone to more false alerts as soon as I got on the road,
    I refitted my antenna and this time fitted it horizontal with a slight tilt towards road.
    Wow this gave me 700 Mtrs on that same Van!
    I think its a great idea for antilaser to look at hiring a Gasto so it can be tested in a controlled conditions,
    Who pushes and knows when the button is pushed to check cars speeds,
    I'm not a expert on operating a Gasto,
    Though once I parked within 5mtrs of the van and was there for 8mins without a hit off my detector He obviously realized I was sitting there with a R.D wandering why I wasn't getting any alerts,[
    Here is a pic of my Local speed 4wd He is watching Midget PORN WE KNOW IT
    Just something for Antilaser to consider
